[XT] Membermap
XF2.x [XT] Membermap 1.0.5 Patch 1
Guck dir mal die Paypal Mastercard an. Solltest du ein Paypal Konto haben wäre das interessnt.
Hab nu eine bei meiner Hausbank - widerwillig meinerseits - bekommen und Google glücklich gemacht mit weiteren Kreditkartendaten. ;)
Maps in allen 3 Foren funktionieren wieder...
Running Membermap 1.0.5 Patch 1 and Xenforo 2.3.4 and when using the "light" style in Xenforo the members pin pop-up shows the X to close:
But when using the "dark" style the members pin pop-up X is there, but not viewable:
It looks like that button has some hardcoded CSS code, but I can't seem to find where exactly that CSS is so I can change it:
Any suggestions?
Hi, habe mal einen kleinen Fehler ...
ErrorException: Template error: [E_USER_WARNING] Method canViewXtMembermap is not callable on the given object (XF\Entity\User)
src/XF/Template/Templater.php:1295
HTML:
Stack-Trace
#0 [internal function]: XF\Template\Templater->handleTemplateError(512, '[E_USER_WARNING...', '/mnt/web003/c0/...', 1295)
#1 src/XF/Template/Templater.php(1295): trigger_error('Method canViewX...', 512)
#2 internal_data/code_cache/navigation_cache.php(501): XF\Template\Templater->method(Object(XF\Entity\User), 'canViewXtMember...', Array)
#3 src/XF/Template/Templater.php(8262): XF\Pub\App->{closure}(Object(XF\Template\Templater), 'forums', Array)
#4 src/XF/Pub/App.php(625): XF\Template\Templater->renderNavigationClosure(Object(Closure), 'forums', Array)
#5 src/XF/Pub/App.php(576): XF\Pub\App->getNavigation(Array, 'forums')
#6 src/XF/App.php(2571): XF\Pub\App->renderPageHtml('
    <div...', Array, Object(XF\Mvc\Reply\View), Object(XF\Mvc\Renderer\Html))
#7 src/XF/Mvc/Dispatcher.php(414): XF\App->renderPage('
    <div...', Object(XF\Mvc\Reply\View), Object(XF\Mvc\Renderer\Html))
#8 src/XF/Mvc/Dispatcher.php(66): XF\Mvc\Dispatcher->render(Object(XF\Mvc\Reply\View), 'html')
#9 src/XF/App.php(2824): XF\Mvc\Dispatcher->run()
#10 src/XF.php(814): XF\App->run()
#11 index.php(23): XF::runApp('XF\\Pub\\App')
#12 {main}
HTML:
Status der Anfrage
array(4) {
  ["url"] => string(42) "/threads/neues-ketron-update.260539/latest"
  ["referrer"] => bool(false)
  ["_GET"] => array(0) {
  ["_POST"] => array(0) {
Hat jemand eine Idee, wie ich das weg bekommen kann?
Danke
Was sagtn das Servereigene Errrorlog zu dem Ereignis?
Hallo
Bei mir wurden neue User nicht eingetragen in der MM
Nun habe ich mal "alles" versucht
beim Eingeben der Schlüssel kommt
dieser Fehler:
neue Schlüssel erstellen lassen
aber der Fehler bleibt.
Hat einer eine Idee?
weil "rausschmeißen" will ich die Karte ungern
oder gibts bei XF nun eine alternative?
Gruß Jo
Ja, dass etwas mit dem Key nicht passt.
Hey
Hier noch die Lösung:
Ich habe die alten Schlüssel gelöscht und beide neu erstellt
damit gehts dann nun wieder so wie es soll
eigentlich kann ich es nur so erklären das die alten Schlüssel abgelaufen waren ?!
Gruß Joachim
Man braucht ja den Geocoding API (API-Key). Was sind denn Eure Erfahrungen bei den Kosten? Denke nicht, dass so viele User die Maps im Monat aufrufen, dass man über 10.000 Views kommt, aber was ist mit Boots und Aufrufen?
Schuhe haben sich bisher nicht als Problem erwiesen und ab davon habe ich die Karte schon aus Privatsphäregründen so eingestellt, dass nur eingeloggte Mitglieder sie aufrufen können. Ansonsten hängt die Zahl der Aufrufe natürlich von der Grösse Deines Forums ab. Viel ist es aber nicht (und im API Log habe ich schon seit gefühlt 100 Jahren keinen Eintrag mehr gesehen - vermute aber, dass das schlicht nicht mehr das tut, was es soll).
Sollte natürlich Bots heißen :)
Danke für die Antwort.
Bisher hatte ich dadurch keine Kosten.
Ich auch bisher Null und nutzer die Map in 7 Foren mittlerweile...
Gäste haben keinen Zugriff.
Registrierte nur dann, wenn diese sich selbst in der Karte anzeigen lassen (fair play ;) )
  • Like
Reaktionen: mph
meine Karte is auch nur von registrierten und eingeloggten Usern zu sehen. Den Rest der Welt geht das ja auch nix an.
  • Like
Reaktionen: mph
