- 28. März 2013
- 2.2.10 PL1
- XF Instanz
- Hosting
- 8.1,x
- MySQL/MariaDB
- 10.5.x
- Dogado
Hi,
habe bei mir das Problem das die Umleitung auf www nicht korrekt arbeitet , da fehlt ein Slash
http://android-port.de/forums/ wird so auf http://www.android-port.deforums/ umgeleitet jemand eine Idee?
Das ist meine .htaccess datei:
MFG
# Mod_security can interfere with uploading of content such as attachments. If you
# cannot attach files, remove the "#" from the lines below.
# <IfModule mod_security.c>
# SecFilterEngine Off
# SecFilterScanPOST Off
# </IfModule>
ErrorDocument 401 default
ErrorDocument 403 default
ErrorDocument 404 default
ErrorDocument 500 default
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{HTTP_HOST} !^www\.android-port\.de [NC]
RewriteRule (.*) http://www.android-port.de$1 [R=301,L]
# If you are having problems with the rewrite rules, remove the "#" from the
# line that begins "RewriteBase" below. You will also have to change the path
# of the rewrite to reflect the path to your XenForo installation.
RewriteBase /
# This line may be needed to enable WebDAV editing with PHP as a CGI.
RewriteRule ^.*$ - [NC,L]
RewriteRule ^(data/|js/|styles/|install/|favicon\.ico|crossdomain\.xml) - [NC,L]
RewriteRule (robots\.txt)$ robots.php [NC,L]
</IfModule>
<IfModule mod_deflate.c>
AddOutputFilterByType DEFLATE text/plain
AddOutputFilterByType DEFLATE text/html
AddOutputFilterByType DEFLATE text/xml
AddOutputFilterByType DEFLATE text/css
AddOutputFilterByType DEFLATE text/javascript
AddOutputFilterByType DEFLATE application/xml
AddOutputFilterByType DEFLATE application/xhtml+xml
AddOutputFilterByType DEFLATE application/rss+xml
AddOutputFilterByType DEFLATE application/atom_xml
AddOutputFilterByType DEFLATE application/javascript
AddOutputFilterByType DEFLATE application/x-javascript
AddOutputFilterByType DEFLATE application/x-shockwave-flash
</IfModule>
<IfModule mod_expires.c>
ExpiresActive On
ExpiresByType text/css "access plus 1 week"
ExpiresByType application/javascript "access plus 1 month"
ExpiresByType application/x-javascript "access plus 1 month"
ExpiresByType image/gif "access plus 1 month"
ExpiresByType image/jpeg "access plus 1 month"
ExpiresByType image/png "access plus 1 month"
ExpiresByType image/x-icon "access plus 1 year"
</IfModule>
<FilesMatch "\\.(js|css|html|xml)$">
SetOutputFilter DEFLATE
</FilesMatch>
</IfModule>
MFG
