- 20. Feb. 2011
Hallo
seit dem Update habe ich nur Problem
und dann kann ich keine neuen themen erstellen siehe Bild
#0 /var/www/xxx/html/forum/library/XenForo/Option/StyleChooser.php(55): XenForo_Model::create('XenForo_Model_s...')
#1 /var/www/xxx/html/forum/library/XenForo/Option/StyleChooser.php(39): XenForo_Option_StyleChooser::_render('option_list_opt...', Object(XenForo_ViewAdmin_Option_ListOptions), 'options', Array, false)
#2 /var/www/xxx/html/forum/library/XenForo/Option/DefaultStyle.php(15): XenForo_Option_StyleChooser::renderRadio(Object(XenForo_ViewAdmin_Option_ListOptions), 'options', Array, false)
#3 [internal function]: XenForo_Option_DefaultStyle::renderOption(Object(XenForo_ViewAdmin_Option_ListOptions), 'options', Array, false)
#4 /var/www/xxx/html/forum/library/XenForo/ViewAdmin/Helper/Option.php(299): call_user_func(Array, Object(XenForo_ViewAdmin_Option_ListOptions), 'options', Array, false)
#5 /var/www/xxx/html/forum/library/XenForo/ViewAdmin/Helper/Option.php(71): XenForo_ViewAdmin_Helper_Option::_renderCallbackOptionHtml(Object(XenForo_ViewAdmin_Option_ListOptions), 'options', Array, false)
#6 /var/www/xxx/html/forum/library/XenForo/ViewAdmin/Helper/Option.php(33): XenForo_ViewAdmin_Helper_Option::renderPreparedOptionHtml(Object(XenForo_ViewAdmin_Option_ListOptions), Array, false, 'options')
#7 /var/www/xxx/html/forum/library/XenForo/ViewAdmin/Option/ListOptions.php(30): XenForo_ViewAdmin_Helper_Option::renderPreparedOptionsHtml(Object(XenForo_ViewAdmin_Option_ListOptions), Array, false)
#8 /var/www/xxx/html/forum/library/XenForo/ViewRenderer/Abstract.php(222): XenForo_ViewAdmin_Option_ListOptions->renderHtml()
#9 /var/www/xxx/html/forum/library/XenForo/ViewRenderer/HtmlAdmin.php(63): XenForo_ViewRenderer_Abstract->renderViewObject('XenForo_ViewAdm...', 'Html', Array, 'option_list')
#10 /var/www/xxx/html/forum/library/XenForo/FrontController.php(533): XenForo_ViewRenderer_HtmlAdmin->renderView('XenForo_ViewAdm...', Array, 'option_list', NULL)
#11 /var/www/xxx/html/forum/library/XenForo/FrontController.php(156): XenForo_FrontController->renderView(Object(XenForo_ControllerResponse_View), Object(XenForo_ViewRenderer_HtmlAdmin), Array)
#12 /var/www/xxx/html/forum/admin.php(13): XenForo_FrontController->run()
#13 {main}
